gasket for the air box in a 2003 Monte SS?
Old Feb 19, 2012 | 05:47 PM
kc2kth's Avatar
Default gasket for the air box in a 2003 Monte SS?
While cleaning my K&N drop in air filter this weekend I noticed the gasket is in really bad shape around the section of the stock air box that is removed when working on the air filter. The gasket is no longer attached to the box and is difficult to get to seat properly when closing the air box back up. It's also started to tear in one corner. I can't seem to find this part listed either at RockAuto or PartsGeek - both offer only a complete air box replacement. Does anyone know if I can buy one of these and replace the old one, or should I just pick up some weatherstripping and replace it with that?
Old Feb 19, 2012 | 05:57 PM
Franks 03SS's Avatar
2011 Monte Of The Year
i didnt know they had a gasket??
Old Feb 19, 2012 | 09:22 PM
kc2kth's Avatar
My factory box definitely has one. It's a rubber gasket around the perimeter of the box on the side that you remove. Most of it is still adhered very well to the box, but the bottom has collected some excess K&F filter oil over the years and that has caused the gasket to come away. I was actually surprised how much of the oil was on that gasket. I've always thought I was careful about not using a lot on the filter, but apparently I went overboard on a couple of occasions.
Old Sep 8, 2012 | 07:02 PM
Marine57's Avatar
Default Gasket for the air box in a 2004 Intimidator too
I'm a few months late on your thread, but I clean my K&N every August. I ran into the same issue on my '04 Intimidator. I noticed how the K&N oil was making it loose and harder to work with and this year mine got torn. I carefully put it pack together. My brother happened to be over and he thought the facorty gasket wasn't needed with the K&N filter and that's why it was a tight fit. So here I am trying to find an answer to question. Doesn't seem to be a common topic. I'll post a solution if I find one.
New2MonteNY
Apr 25, 2017 01:59 PM
TatteredMind
Mar 15, 2014 09:51 PM
Hasnolimits
Feb 14, 2013 09:13 AM
prez
Jun 6, 2009 11:41 AM
rrobert05
Dec 17, 2006 01:26 PM
