fuel system list
Old 07-13-2010, 09:13 PM
02montecarlo's Avatar
I would completely take the throttle body off the engine to clean it. The side facing the engine is going to be the dirtier of the 2.
Take the intake hose off, take the engine cover off. Unbolt 3 bolts and the connectors and the TB slides right off. 89 IN/lb when you put it back on.
Bank 1 o2 sensor is on the rear manifold. Not the easiest to get to, but not entirely hard either.
Don't I need to replace the gasket and drain the coolent to do that...or no?
Old 07-14-2010, 12:25 AM
PacerSS's Avatar
No, you don't need to drain the coolant. Only about 2-3 tsp should come out. As far as the gasket I'm pretty sure you could re-use it since it's rubber. But if you have a lot of miles it might be a good idea to replace it.
Old 07-14-2010, 12:32 AM
[QUOTE=PacerSS;246119]No, you don't need to drain the coolant. Only about 2-3 tsp should come out. As far as the gasket I'm pretty sure you could re-use it since it's rubber. But if you have a lot of miles it might be a good idea to replace it.[/QUOTE
Yeah she's got 220,000 on her n I can see a lil bit of a gap as well so I mine as well since its gonna be off anyhow. That would be the upper intake manifold gasket if I'm correct right?
Old 07-14-2010, 12:38 AM
PacerSS's Avatar
No, throttle body gasket. Huge difference between the two. The gap is not necessarily a bad thing. The gasket is pretty thick, if torqued down correctly there is a slight gap between the UIM and TB.
Old 07-14-2010, 12:41 AM
O my bad...hahaha I'm a bit tired. If that were leaking the tb gasket could that affect my fuel mileage?
Old 07-14-2010, 01:55 AM
PacerSS's Avatar
It could but they rarely do. Your LIM(lower intake manifold) gasket is probably the first of gaskets to go on these cars. That leaking could definitely cause an MPG problem.
Old 07-14-2010, 08:08 AM
I wouldn't reuse the TB gasket. I thought mine looked fine, and then on the highway I heard a very distinct whistle, and had to buy a new gasket.
Better to just do it once, then have to take it apart again.
ladybridgeport
02-07-2012 05:03 PM
JaxJim
09-18-2010 08:24 PM
02montecarlo
07-07-2010 11:41 AM
aussiek2000
02-27-2009 07:31 AM
J_Bru_Ha_SS
08-16-2006 04:03 PM
Quick Reply: fuel system list
