fuel filter
Old Jan 14, 2014 | 05:32 PM
dave countie jr's Avatar
Default fuel filter
hi kids, happy new year to all. where is the fuel filter on a 04 3.8? is this a big deal to do or is this a goodwrench issue?
Old Jan 14, 2014 | 06:11 PM
djhixter's Avatar
i know on my 02 ss, it's right in front of the fuel tank...towards the front of the tank...just make sure that the fuel line fitting that screws into the filter isn't too terribily rusty...if it is, you may have to repair the fuel line
Old Jan 14, 2014 | 06:22 PM
Habbibie's Avatar
Mine s located just in front of the driver rear tire. Has those quick disconnects which are nothing close to quick lol mine is a 3.4 though
Old Jan 14, 2014 | 06:23 PM
djhixter's Avatar
the 04 has one quick disconnect and at the other end should be have the screw in fitting...the quick disconnect is so much better
Old Jan 14, 2014 | 06:38 PM
Habbibie's Avatar
LoL I'm opposite of you screw fitting is ten times easier but I think the subject has been resolved now
Old Jan 14, 2014 | 06:49 PM
djhixter's Avatar
the problem with the screw fitting is the rust...especially here, where road salt rusts the fitting to the filter resulting in fuel line repairs...
Old Jan 14, 2014 | 09:03 PM
The '00-'05 Monte and Impala, regardless of engine type has the filter in the same spot. I have seen two different styles of "quick" connects, luckily, neither style has given me any issues.
And I completely agree!!! That filter is in a BAD spot and gets salt abuse badly.
One tip I'm currently testing out, after you change it and the fittings are tight, pack grease around the exterior of the fitting. I've been told by others that have tried this, when you go to change the filter again, wipe it off and should be pretty well preserved. Time will tell.
Old Jan 16, 2014 | 02:29 PM
thx all who responded.
Slamjunk
Sep 29, 2014 03:56 PM
MJClemm
Mar 18, 2013 07:10 PM
01BlkSS
Jan 12, 2007 12:03 AM
malletboy
May 17, 2006 09:38 AM
jg
May 7, 2006 01:57 PM
