Fuel filter replacement
Old Jan 8, 2007 | 06:40 PM
01BlkSS's Avatar
Default Fuel filter replacement
Is it very hard to replace the fuel filter on a 01 Monte SS? It's pretty cold up here and I don't want to start on it if it will take a while. Thanks!
Old Jan 8, 2007 | 08:21 PM
InTheIROC's Avatar
Default RE: Fuel filter replacement
It's easy... two quick disconnect fittings and a bolt and it's off.
Old Jan 8, 2007 | 09:18 PM
01BlkSS's Avatar
Is it back by the tank?
Old Jan 8, 2007 | 11:25 PM
InTheIROC's Avatar
It's on the driver's side, before the LR wheel
Old Jan 9, 2007 | 01:33 AM
2000LS's Avatar
mine has 1 quick connect and one fitting, and then clamped on. the clamp is typicly held by a 13mm bolt, then i use a 16mm and a 20mm wrench on the fitting, but 5/8 and 13/16 should work too
Old Jan 9, 2007 | 04:25 AM
01BlkSS's Avatar
Cool, thanks for the wrench sizes. I always end up with the wrong sizes when I'm working on something. I'll be prepared this time.
Old Jan 9, 2007 | 04:52 PM
benhillzone3's Avatar
you can never go wrong by asking these guys in there they are very knowledgable
Old Jan 9, 2007 | 10:00 PM
InTheIROC's Avatar
Oops, maybe it is one quick connect. I forgot, it's been a while since I did mine.
Old Jan 10, 2007 | 03:57 PM
hckygoalie31's Avatar
Another thing too...I replaced mine last year. I think it's actually threaded backwards. So instead of "righty Tighty, Lefty Loosey"...go the opposite.
BTW...a golf tee works great to plug the gas line when you change the filter.
Old Jan 10, 2007 | 04:45 PM
01BlkSS's Avatar
Too bad I don't golf or that would have come in handy! [8D]
I replace the filter when I had an older deville and I forgot to loosen the cap on the gas tank and it was about -10 outside and the gas burnt my arm. It was not a pretty sight. Live and learn I guess...
