Front end noise 2003 3.4 litre
Old Jan 17, 2011 | 08:50 PM
shovelhead pete's Avatar
Default Front end noise 2003 3.4 litre
Glad I found this forum, looks like a wealth of info here. This is my first post, so here goes:
I just bought a 2003 monte LS 3.4 litre. It has 112,000 kilometeres on it (canuck here)
I have a front end humming noise/slight vibration coming from the front end. It varies when I turn the steering slightly from side to side. I think it's a bearing or could it be out of alignment? The sound goes away almost completely when I track slighty to the right. Also when backing out of a parking spot, if i crank the wheel over all the way then pull forward there is a growling noise and my TRAC message comes up, but then goes away after a few yards of driving. This doesn't happen every time, though. Any ideas anyone?
Old Jan 17, 2011 | 09:33 PM
BocaReject's Avatar
sounds like the wheel bearing is going
Old Jan 20, 2011 | 05:04 PM
kazuya's Avatar
If this pulsating feel when you press the brake petal, you probably need the rotors turned on front of vehicle, this should be done every time you install new brake pads.
Old Mar 15, 2011 | 11:19 AM
charlieice4's Avatar
Probably the bearing, they are fairly easy to replace. Autozone has a good writeup on how to do it and sells them for $90 with a 1 year warranty. Autozone will loan you the large socket you need to take off the axle nut.
Old Nov 24, 2012 | 02:25 PM
Osiris's Avatar
Default Dirty ABS sensors
I was having the same grinding noise after backing out of a spot, etc. It became progressively worse throwing ABS and TRAC codes. Here is what I did: I cranked the wheels and disconnected the sensors at the harness that connects the integrated wheel bearing assembly to the electrical system. Once disconnected, spray both male and female components thoroughly with electrical component cleaner (available at Oreilly, etc.). Wipe them off and reconnect. Fixes the computer erroneously misreading wheel speed, etc. and throwing lights. Hope it works.
Old Nov 24, 2012 | 11:52 PM
chevy202's Avatar
id say wheel bering as well.....very common issue..
bthmetal87
Jul 24, 2011 11:32 PM
Coors
Jan 22, 2011 11:27 AM
roboticboredom
Nov 26, 2008 04:26 PM
mike01ss
Jul 16, 2007 01:09 PM
jogasz28
14
Oct 30, 2006 11:01 PM
