front cig lighter help
Old Sep 6, 2009 | 03:35 PM
weizie's Avatar
Default front cig lighter help
I unplugged my radars power cable, but the tip and the fuse broke and stayed in there. Well I got them out but now the lighter power source doesn't work. I checked the fuse in the side of the dash, it was fine but I replaced it anyways and its still not working. I think I fried the actual lighter part its self. And I can't find any other fuses that look like they might even be for the lighter. Please all help is highly appreciated the sooner the better.
Old Sep 6, 2009 | 06:27 PM
RocknSS04's Avatar
Highly possible it's fried. There are 2 screws under the rubber mat both in the cubby hole area and in the armrest. Remove them and get to the lighter from behind. It's easy to do. Put on the parking brake also, and drop the tranny down into low to help removing it. There is a clip on the shifter handle that can come off, but that shouldn't be necessary.
Check to make sure you have voltage at the wires, and if so, you know your recep' is fried.
Old Sep 8, 2009 | 08:01 AM
weizie's Avatar
Ok sounds good ill be doing that today when I get out of class.
Old Sep 11, 2009 | 11:32 AM
weizie's Avatar
well i unplugged the lighter and used the meter on it and i got nothing from it. so are there some other fuses that i am not aware of that i need to check?
1SLOWSS
Nov 28, 2012 08:30 PM
aaronkt
Dec 4, 2008 04:27 PM
Endo
Jan 25, 2008 12:49 PM
manny
Sep 23, 2007 02:11 PM
smyurick
Jul 30, 2007 07:18 AM
