cig lighter
Old Sep 10, 2007 | 01:24 PM
manny's Avatar
Default cig lighter
hello
my problem is
my 02ss the cig lighter plug is not working anymore it was working fine but its gone now so i use the one on the back for my sirus radio......
and this same thing happen on my dads car 03impala
anyone had this problem .its not the fuse
Old Sep 10, 2007 | 02:30 PM
04 Intimidator's Avatar
Default RE: cig lighter
Never heard of them going out that quick. Can you check to see if you are getting power with a continuity tester first inside the lighter and then outside on the wires?
If good on the wires then it is a bad lighter outlet and needs to be replaced. If not good at the wires just outside the lighter it is probably going to be closer to the fuse block. Most chances is the lighter outlet is broken and needs to be replaced.
Old Sep 10, 2007 | 04:40 PM
HyperFox's Avatar
I second that. I know the wiring of the 06-7 cig plugs and I imagine its the came. If your front works, but your rear doesnt, you could pretty much bet on the lighter being pooched or, the wiring harness has come off the back as the front and back use the same cuircuit with a 10A fuse.
Old Sep 10, 2007 | 07:26 PM
rj's Avatar
rj
If your a smoker the lighters or sockets tend to wear out. It's not that they actually wear out, it's more the heating/cooling, heating/cooling process of using the lighter. A build up of corrosion makes it so the lighter and/or socket doesn't work now cause of the corrosion.
Old Sep 10, 2007 | 07:41 PM
HyperFox's Avatar
Yeah.. What he said.
Old Sep 23, 2007 | 11:18 AM
manny's Avatar
holy crap i forgot about this post ...sorry bout that
well i have changed everything on it and new outlet a new lighter still nothing .....
i was using a a pump at home to pump my tire and it just went out .....
back one still working fine fuse is fine ....only thing i can think of now is the harness? i dont know
Old Sep 23, 2007 | 11:46 AM
Manny, did you put in a new socket ? New Lighter ?
Is the rear one still working ? Did you re-check the fuse ?
(Wet you finger, & put it in the socket : )
No, just kidding
Youneed 2 find out if the center contact has 12 Volts by using a Volt meter, & if it has a good ground. Some lighter use a 20 or 30 amp fuse .
[align=center]When I have a problem like that I stop in @ a garage, & ask one of [/align][align=center]the tech's, or stop by a stereo install shop, & usually they will give you [/align][align=center]some help. Good Luck, `Space[/align]
Old Sep 23, 2007 | 02:11 PM
ORIGINAL: manny
So it sounds like you replaced the whole cig lighter unit. Did you test if you are getting electricity to that unit yet?
1SLOWSS
Nov 28, 2012 08:30 PM
weizie
Sep 11, 2009 11:32 AM
smyurick
Jul 30, 2007 07:18 AM
ddschneider1972
Jan 7, 2007 11:12 AM
01ss
Aug 24, 2006 12:04 PM
