How to remove center console
Old Sep 11, 2009 | 09:25 AM
paintballerr78's Avatar
Default How to remove center console
I have a 2003 monte carlo ss and i cannot find out how to remove the center console. I found the screw in the front cubby hole that was the only screw i found. What other screws do i need to remove to get my center console out?
Old Sep 11, 2009 | 10:59 AM
03Monte's Avatar
There are screws under the arm rest, and once you remove the top there are a few more screws.
the top cover should just pull right up (with a little pressure, don't yank it as you may break it)
Old Sep 11, 2009 | 11:12 AM
are the screws under the rubber mat in the arm rest? Because i see 4 like bolts under the rubber mat
Old Sep 11, 2009 | 11:22 AM
03Monte's Avatar
yes, they are under the rubber mat.
have you poped the top off yet? (where the shifter/cup holders are)?
Old Sep 11, 2009 | 11:36 AM
no i havent im going to try and take off that part today so i can see whats wrong with Cig lighter
Old Sep 11, 2009 | 12:00 PM
how would i go about jsut removing the top piece of the center console
Old Sep 11, 2009 | 12:06 PM
03Monte's Avatar
it should just pop right off, be careful to not apply to much pressure, you don't want to snap it in half..
Old Sep 11, 2009 | 12:19 PM
i just took it off i couldnt find anything wrong with the wires connected to the cig outlet what else could be wrong i already changed the fuse
Old Sep 11, 2009 | 12:23 PM
since it's all apart why not just buy a new cig lighter and put it in?
Old Sep 11, 2009 | 12:26 PM
03Monte's Avatar
i agree, i plan on buying a new one, but i have not got around to it yet.
milrlyt
FWD Tech Guides '95-'07
Aug 24, 2022 06:54 PM
sorcier11
Sep 4, 2009 12:31 PM
