A few questions I have
Old Mar 10, 2010 | 11:48 PM
Jmontross89's Avatar
Default A few questions I have
The first one is I just replaced my gas cap this past weekend since the stock one was worn out. After replacing it I still get on my DIC "TIGHTEN GAS CAP" and then the service engine light. I've tightened and what not but still same thing (not as often). Any suggestions? Also with my keyless entry and remote start I have to be within about 5 feet of the car for it to work and I don't know how I can make that range longer I replaced the batteries and again still same issue. Thanks if you can help me out!
Old Mar 11, 2010 | 09:20 AM
kweef's Avatar
the year and model of your car would help
Old Mar 11, 2010 | 10:52 AM
My bad its a 2006 Monte Carlo LT
Old Mar 11, 2010 | 11:16 AM
There's a TSB about the remote distance. A dealership should be able to fix that for you.
As for the tighten gas cap, it takes a bunch of cycles before the code will go away, maybe disconnect your battery for like 30 minutes to clear the codes and see if it comes back. If it keeps coming back it could be an electrical issue with your car and could still be covered under an extended (emissions) warranty.
Old Mar 11, 2010 | 11:34 AM
Okay thank you very much for the help on both forums for me.
Old Mar 11, 2010 | 12:35 PM
K-Mac Attack's Avatar
Did you get an OEM gas cap or an aftermarket one from a parts store. Often the aftermarket ones will still cause codes to come up.
Jomao_o
Dec 29, 2013 04:34 AM
n0va
Nov 3, 2010 03:28 PM
montecarlocrazy
Oct 5, 2010 10:28 PM
72MonteCarlo
Mar 3, 2006 09:53 AM
kissmyss03
Jun 30, 2005 12:18 PM
