Fan control code
Old Mar 29, 2016 | 11:54 AM
SSBlue's Avatar
Default Fan control code
Hiya everyone, this is a problem I'm having difficulties with and could really use some help. I have an '01 SS 3800 n/a, and it has a secondary fan control code. I tested the fans and they work properly, and I found that it apparently blows the 25a fuse for it too. I believe it is keeping my a/c from working as well. Only part left I haven't replaced is the relay. I've checked the site as best as I can and can't seem to find anything about it. Anyone have any guidance or experience with this issue?
Old Mar 29, 2016 | 12:22 PM
Below from Mr Google,
I hope it may help until a member post on your problem> Good LucK<
Try removing all fan relay's coat them with dielectric grease, plug them back in and this should work.
Radiator Fan Problems - Monte Carlo Forum - Monte Carlo Enthusiast ...
montecarloforum.com › ... › Engine/Transmission/Performance Adders
Aug 14, 2011 - For about a year now my radiator fans havent worked, but with the fact the 80% of my ... 2003 Chevrolet Monte Carlo ... only problem was something about the fan control module if i remember correctly, the code isnt important. ... The red box is the fuse that keeps blowing, a 25 amp. ... 08-16-2011, 01:24 AM ...Problem with Fan/Blower Switch - Monte Carlo Forum - Monte ...
Aug 17, 2010
fan, heater, a/c stopped working - Monte Carlo Forum - Monte ...
Jan 4, 2010
cooling fans not working!!!!!!!!!!!! - Monte Carlo Forum
Oct 2, 2009
Cruise and Heat Broke!!!! Please help - Monte Carlo Forum ...
Oct 20, 2008
More results from montecarloforum.com
Chevrolet Impala Questions - problem with cooling fans not ...
www.cargurus.com › Questions › Chevrolet › Impala
CarGurus
Jul 18, 2007 - problem with cooling fans not coming on - cooling fans don't come on,when ... #1 fan fuse blows when I turn the ac on in 2001 Monte Carlo SS ... With the blower motor control on five the a/c doesn't blow like its on five. i've ...
https://www.youtube.com/watch?v=y5UuO89CFJI
Jul 15, 2014 - Uploaded by 1A Auto Parts
... how to repair, install, fix, change or replace a bad or broken blower motor fan sp. ... Heat AC Fan Speed ...
Chevrolet Monte Carlo Electrical Problems - Car Forums at Edmunds.com
forums.edmunds.com › Chevrolet › Chevrolet Monte Carlo
Learn more about Chevrolet Monte Carlo at the Edmunds.com Car Forums! ... I am having problems with my 2001 Monte Carlo SS. .... I have a 2000 monte carlo ss and it keeps blowing the fuse that controls my cooling fans causing my car to ...
Fan not working, Monte Carlo 2000 - DoItYourself.com Community Forums
www.doityourself.com/.../372928-fan-not-working-monte-carlo-2000-a....
Dec 26, 2008 - 12-26-08, 01:18 PM #4 ... I thought it was the fan motor but not blowingthe fuse purplexed me. ... Is there a fuse(in the fuse box) for each speed on the fan or is that the job of the resistor? ... Monte Carlo SS 2000--does anyone have a schematic for where it is located and what it looks like--is it a module or ?
fan speed 1 and 2 not working but 3 & 4 speed working fine ...
www.topix.com › Chevrolet Impala
Aug 9, 2007 - When I turn the heat or air condition on the fan doesn't blow out any air unless I turn up ... Would it be a fuse that controls only the first two speeds? .... I have always bought Chevy products but must admit, with the problems I ...2002 Chevy Monte Carlo SS - Service Traction Sytem
May 4, 2010
2001 impala ls temp gauge and ac problems
Jan 27, 2008
More results from www.topix.com
Old Mar 29, 2016 | 08:12 PM
SSBlue's Avatar
The code is P0481, btw. Any additional help is greatly appreciated.
Old Mar 30, 2016 | 08:58 AM
Thanks, Good Luck
Old Mar 30, 2016 | 09:12 AM
SSBlue's Avatar
I appreciate your guidance mike... And thank you for the good wishes... I think I'm gonna need it. Lol
Old May 13, 2016 | 10:56 PM
SSBlue's Avatar
I think I fixed it. I replaced the black center fan relay and fuse. Fuse hasn't blown and the code has stayed cleared.
