failed emission test
Old Nov 6, 2010 | 09:18 AM
jarheadbobandmax's Avatar
Photobucket
Default failed emission test
does anyone know what the DTC (PO137) is? failed emission test...Thanks
Old Nov 6, 2010 | 09:35 AM
..Hi Tim, well that sucks 4-Sure...
Hope the below helps, until one of our expert tech's reads about your code & problem...Good Luck on a resolve 2 the prob...
It means that the sensor behind the convertor is not producing voltage properly or being read properly.Usually its a bad O2 sensor but could be in the wiring to the sensor or the PCM.I would change the sensor and have the code cleared and see what happens.
Read more: What does the code PO137 O2 Sensor Circuit Low V... - JustAnswer http://www.justanswer.com/questions/...#ixzz14VsOdW1h
Old Nov 6, 2010 | 03:06 PM
nemesis's Avatar
2009 Monte Of The Year
LMFAO good job chump....i passed mine with no cat converter 2 months ago. i do have the 02 sensor if you need it. have less than 27k miles. you can have it FREE.
Old Nov 6, 2010 | 03:53 PM
Photobucket
U da Man!!!!!!! I'll pm you the address and catch up with you
acts121
Mar 2, 2012 09:23 AM
04 Intimidator
Dec 21, 2007 02:33 PM
rcohen
Feb 22, 2007 05:12 AM
Phat305
Apr 30, 2006 03:19 PM
batman
Oct 15, 2005 03:26 AM
