Engine Swap in a 2000 Monte SS
Old Feb 29, 2012 | 01:05 AM
crete's Avatar
Default Engine Swap in a 2000 Monte SS
I spun a bearing in my motor so I went and bought a used engine with 70k on it. Same motor, it came out of a 2002 Bonneville.
I'm getting ready to do the swap now. Any advice?
I didn't see a how-to on this and I am looking for something to study.
Old Feb 29, 2012 | 01:09 AM
jwjones's Avatar
Should do a top swap while you doing all this work. Or should have just looked for a SC'd motor
Old Feb 29, 2012 | 06:56 AM
If you have never done this before I would get a haynes or chilton manual for starters. Autozone or Oreileys should have one or check your local library. As for the swap the best advice I can give is label everything. Ziploc bags and a sharpie work good for storing bolts or small parts. Take pictures along the way to help remember how wires or hoses are run.
Old Mar 5, 2012 | 02:08 AM
crete's Avatar
Yeah I've swapped a 350 into my 79 grand prix. Just never did it on this car. I'm assuming it will be pretty straight forward but I figured I would check the forum to see if there was any advice available before I start on it.
Old Mar 5, 2012 | 10:21 AM
Well it's recommended you pull most motors out the bottom nowadays. All you do is dropp the cradle and go from there. I have done a few on front wheel drive vehicles and I've pulled them from the top. You may have to end up pulling more things off the engine.
Old Mar 5, 2012 | 11:43 AM
turbo monte's Avatar
i pulled mine from the top and left the trans in the car. pretty simple, just label everything and pics do help. good luck!
Old Mar 5, 2012 | 11:49 AM
BlackRainSS's Avatar
Some people may not always want the supercharged engine. It is an extra cost but way worth it in my opinion. However having owned a N/A 3800 also I would say they are great enignes also.
bryan_p88
Apr 13, 2012 09:24 PM
Budsjlm
Apr 3, 2012 05:43 PM
TyFerris
17
Jan 13, 2012 04:35 PM
biglfla80
Nov 11, 2010 11:38 AM
