Electrical Issues Interior/Exterior
Old Jul 7, 2011 | 01:05 PM
01MoneyCarloSS's Avatar
OK so BIGAL 131, You where having the same issues as me?
Old Jul 8, 2011 | 12:23 PM
BIGAL131's Avatar
01moneycarlo...lol....i like that user name cuz for sure i spent a lot of money on my SS 2002 Pace car as well...I didnt have the exact issues as you but every BCM issue isnt the same on our cars since it does control a lot of the cars electrical system.Some of my issues were as follows:Remote did not lock or unlock my doors at times, The car sometimes didnt start, like it had a dead battery with what sounded like some relays clicking under the drivers side dash then after waiting for a little bit it would start normally, back up lights turned on and off while backing up..very noticeable at night by the way!, No headlight delay when shutting off the car or arming or disarming the alarm, Radio stations in memory would be lost sometimes...would have to put the stations back into radio memory and would loose them again in about a week. All lights including headlights and tailights would flicker while driving at night..some people thought i was flashing them at night...there is more but my fingers are getting tired of typing....hope this answers your question on my BCM issues! Good Luck!
Old Jul 8, 2011 | 01:20 PM
bbengineer's Avatar
Doesn't necessarily sound like a BCM issue to me.. it actually sounds like a few discrete problems
For the dash lighting problem... does the factory radio display act funny (IE: Is it dim when the odometer is dim?) ? What happens when you rotate the headlight **** to brighten/dim the interior lights? It could be a cluster on the way out or the headlight dimmer switch on the way out
Your gas gauge issue sounds like the sender is bad... very common
Your turn signal issue is likely a bad hazard switch (again, very common). When your signals don't work, turn the hazards on and off a few times and see if they start working
For your headlight issue, check the bulb on the passenger side, check the wiring harness both to the headlight and in the headlight and make sure the ground on the radiator support is good. If you engage the high beams, are they both the same brightness?
BBEngineer
Old Jul 10, 2011 | 12:24 PM
Yes, the factory radio is dim when the odometer is dim. When I rotate the switch nothing happens.
When my turn signals started acting crazy, I hit the Hazard button a few times then they started to work.
The ground to the radiator is fine. All the bulbs work in my head light. No matter which set of lights are on the passenger side is dim. that goes for high beams and low beams. Fog lights and side marker lights re fine.
Old Jul 10, 2011 | 12:59 PM
bbengineer's Avatar
Do the rest of the interior lights dim when you rotate the ****? If not, you need to replace the headlight switch... if they do, then you likely need a BCM
Replace the hazard switch
Replace the 10Amp EXT LTS fuse in the under the hood fuse block... If that doesn't fix it, as an experiment, swap the left and right headlight assemblies and see if it follows the headlight assembly, or stays on the same side of the car... then report your findings back here
BBEngineer
Old Jul 20, 2011 | 12:04 PM
Still working on getting the money for the headlight switch and hazard switch. But I did switch out the 10amp fuse and it did fix my headlight issue...
Thanks...
Old Nov 22, 2016 | 05:41 PM
2001 MCSS's Avatar
Ok, this sounds similar to what I have yet worse.(worse for them not me) A few weeks back my dash lights and console lights went out suddenly. I mean I was driving, stopped for gas, got back in and no more dash or console lights, the cruise light will light, abs seat belt lights and such , just not cluster lights. I went in and found were the fuse was for the clusters and replaced it, it was burnt out. It was good for about a week? Went back out, yet the fuse was not blown this time. I went and switched it again and after a couple tries I got the console to light so I thought I fixed it. Next morning it didn't work again.
I'm at a loss to where to look now. Any help will be greatly appreciated.
carid
Vendor for sale section
21
Aug 1, 2014 09:08 AM
Zeke
Feb 7, 2012 02:42 PM
MonteFirst
Jan 27, 2012 10:55 PM
pattrickw
Nov 7, 2011 11:27 AM
freeguy555
Nov 19, 2007 08:55 PM
