ecu and ac
Old Aug 4, 2009 | 03:30 PM
desertstars's Avatar
Default ecu and ac
Everything checks out with a/c system on '01 MC. Everything. But, contactor won't kick in unless jumped.
Scan shows that juice gets to BCM but no apparent communication with PCM (ECU). All grounds in electrical system are fine. Took it to a dealer and found out the same thing for $102 that I already knew.
Anyone know if flashing the existing ECU might have a good chance to resolve the problem? The only other alternative would be to replace the BCM and if that isn't the problem then replacing the ECU as well.
Naturally, I don't want to end up tossing money at either. Both the BCM and PCM are working properly other than the a/c monitoring and a possible short in the door locks from both the remote and the switches although the security system DOES operate from the remote.
Dam20735
Dec 1, 2012 08:35 AM
02montecarlo
Jul 25, 2010 08:03 PM
cangri_926
15
Mar 3, 2010 06:40 AM
ag3nt0r4ng3
Jul 18, 2005 06:45 PM
