6th Gen ('00-'05): ECM/PCM issue?
Old Jan 29, 2015 | 10:32 AM
Jayhawkbrown's Avatar
Default ECM/PCM issue?
I have a 2001 Monte Carlo 3.4 L that is having intermittent electrical issues. The temperature gauge will stop working from time to time but if I reset the car by taking the negative battery cable off and then back on, it will work fine...for a while. Then the radio will decide not to let sound out of speakers even though it is on...then randomly will start working again. Then the dash lights might decide not to work for a day or two, but then mysteriously work fine. Now my transmission is acting goofy...lower gears switching rough; next day lower gears are fine but won't shift into overdrive on the highway. Could this be a computer problem such as the ECM/PCM? Please help!
Old Jan 29, 2015 | 03:16 PM
Jay:
Sounds like it could be a possible ground issue...
I'd check clean all your battery connections..
Followed by checking/cleaning all your body/chassis Grounds..
Old Jan 29, 2015 | 03:34 PM
JC Colon's Avatar
I agree with Stumpmi, check all your grounds. I would also check your Body Control Module. It controls a lot of those things. Better to check it now then wait until it the stops running!
Old Jan 30, 2015 | 11:55 AM
Thanks for the advice! Is there a good way to check the body control module to determine if it is good or bad?
Old Jan 30, 2015 | 12:09 PM
Below the air intake is a common ground that corrodes. Start there
Old Jan 30, 2015 | 12:31 PM
JC Colon's Avatar
You need a Tech II scanner to check the BMC, ABS, and Transmission!
RDUB8
Nov 7, 2011 12:31 PM
Tdogg527
Feb 11, 2010 07:44 AM
xman23
Jul 13, 2008 04:41 PM
bowtietech
Feb 27, 2008 09:26 AM
Peer81
Mar 8, 2007 06:29 AM
