security light
Old Jan 30, 2015 | 01:34 PM
babyjokerxxxxx's Avatar
Default security light
hey guys cold as heck here so i used my remote starter(auto page)and let my car warm up..it has like a 20 minute timer so after cleaning off snow the car turned off. It started with no problem but my alarm functions arent working now. I cant use the remote start,lock doors,etc. when i try my hazzards just blink. I've read other posts where they cant start the car at all and thank fully that isnt my issue. I have tried pumping brakes on acc.,pulling headlight switch 3 times,im not sure if unplugging the battery terminal will work. Any ideas? I havent checked any relays or fuses yet.
Old Jan 30, 2015 | 03:10 PM
Is it a factory alarm?
If its an aftermarket.. I would recommend taking it to get it checked.
It maybe a PCM issue...
My wifes 03 GMC Sierra has a PCM with no memory to keep the settings..
for an aftermarket alarm/remote start.
I discovered this when I had to change the battery in it.
Maybe it was so cold and had such a low charge..That very same thing may have happened to yours and used up what was left in the battery to get it started.. (Just a thought)
Maybe you have to do a security relearn?
Old Jan 30, 2015 | 06:10 PM
not a factory alarm a whole new system...ive used the remote start for the past 4 years or so ive been up north with the cold weather...but like i said the remote starter once started stays on for 20 minutes then cuts off and today was the only time i let the full 20 minutes run off...so im hoping its just the alarm needs to relearn....i've had this for 10 years so maybe an upgrade is time. thanks STUMPMI!!!!
RonKennesaw
Jan 5, 2015 04:49 PM
EbonyChevyMama
Jan 1, 2015 06:41 AM
lolligirl56
Oct 19, 2009 10:16 PM
okds650
Sep 20, 2006 04:52 PM
