Easy one - identify this part! W/photos
Howdy gang,
My sister-in-law's Monte has been smelling of gasoline after sitting overnight, and upon a brief inspection, I found the culprit. I have searched the forums and even auto parts websites for any part with the word "fuel" in it - can I can't figure out what it is!
I'm sure most of your wizards will know just from looking at it, so here's some photos, TIA!
Thanks so much! The stock photos on all the parts shop websites didn't match, but that was my guess and you've helped me out a TON. Now I won't have to worry about my sister-in-law bursting into flames. Her mother, sure
I don't think I've ever heard of a fuel regulator on a 3100/3400/3800 going bad/leaking. First time for anything.
Was any work recently done to the car (like LIM gaskets)? Given how the UIM is on the 3100/3400 it's easy for a poorly seated fuel injector or a faulty O-Ring (usually from re-using an O-Ring) to cause fuel fumes to appear to be from that location. If you did not see it leaking from the regulator, just take a good look around the injectors and rails to be sure you got the culprit.
6th Gen ('00-'05): Can anyone identify what part this is?
00MonteCarloSS
Jul 3, 2014 07:25 PM
Mitchum5543
May 19, 2009 08:50 AM
