dumbarse didn't change his air filter, dropped a rod
Old Aug 4, 2013 | 02:47 PM
freakert's Avatar
Default dumbarse didn't change his air filter, dropped a rod
I was lazy. which is my better route to take care of this. do I pull the engine, and rebuild, or what years of 3.8l v6 chevy engines will fit a 2002 monte carlo
Old Aug 4, 2013 | 03:10 PM
owens91's Avatar
theres a Buttload of cars that carry the GM 3.8 engine....impalas, a few buicks, grand prix, 2000-2005 montes but you have to get the SS or LT models i believe. im sure there are others which members wil chime in...didnt know an Air filter could cause a rod to go..... i knew an oil filter maybe but ya
Old Aug 4, 2013 | 04:41 PM
Any Series II L36 3800 will fit your 2002. I believe that spans from '97-'04. You might have minor sensor swaps and that's it.
OR, you can upgrade your engine to a Series III 3800 (ran from 2004- until the end of the 3800). I would recommend a 2005+ Series III L26. Again, it's almost a direct swap. You need an adapter for your throttle body (since the Series III is drive-by-wire). And you have to remedy a PCV vac line. In '05+ they used forged connecting rods for better durability (the Series II and the '04 Series III had cast rods).
If my L36 took a dump, I would go for a '05+ L26 without thinking twice.
A fellow MCF member, Frank, had his engine die. Here's the thread about that:
https://montecarloforum.com/forum/en...te-dead-37916/
And here's the beginning of when Frank got the L26 and began working on it to pop in his Monte (lots of pics and lots of information):
https://montecarloforum.com/forum/en...e7/#post480693
Old Aug 4, 2013 | 08:19 PM
freakert's Avatar
Am I ever glad I joined this forum. Thank you ever so much.
Old Aug 4, 2013 | 08:29 PM
owens91's Avatar
hope to see some pics of ya ride, or work in progress
MAMONTE
FWD Tech Guides '95-'07
26
Apr 7, 2015 06:59 AM
ChibiBlackSheep
May 26, 2014 12:51 AM
WannaMCSS
Apr 9, 2012 08:55 AM
YellowBomb
Jan 20, 2009 09:29 PM
White05LT
Nov 18, 2005 10:03 AM
