How change air filter 06 SS
Old Apr 7, 2012 | 04:12 PM
WannaMCSS's Avatar
Default How change air filter 06 SS
Is there a trick or something to changing hte air filter?
I undid the clips at the the top of the box but it doesnt pull apart enough to even pull the old one out?
Am i missing something?
Old Apr 7, 2012 | 04:37 PM
my manual says to loosen the clamp on the inlet tube to the air filter cover also.....
Old Apr 7, 2012 | 06:43 PM
wiseheak's Avatar
I just figured out how to do this the other day. You have to unclip the top clips like you did, and then pull them apart from the top. the plastic shroud on the side towards the engine is actually hooked into the other side by some plastic on the bottom. just pull them away from each other and it should come apart, just make sure you hook them back together on the bottom though
Old Apr 7, 2012 | 06:45 PM
wiseheak's Avatar
Also try to pull the engine side shroud UP and away from the other
Old Apr 8, 2012 | 07:53 AM
WannaMCSS's Avatar
may manual says to loosen the clamp on the inlet tube to the air filter cover also.....
tried all suggestons and this one worked.
Thanks a lot.
I will admit, of all the cars ive owned this was the toughest "simple job" air filter change i ever had.
lining it back up and closing the box took a long time to get right as well.
Old Apr 8, 2012 | 08:36 AM
03SSLE's Avatar
The next time you change the air filter you can make r&r easier by taking the above suggestion a step further. By removing the air duct hose from the inlet of the air box you will eliminate the resistance you were fighting trying to get the air box apart and lining it up after installing the new filter.
Old Apr 9, 2012 | 08:55 AM
I just remove the hose at the TB and it all moves enough
MAMONTE
FWD Tech Guides '95-'07
26
Apr 7, 2015 06:59 AM
ChibiBlackSheep
May 26, 2014 12:51 AM
freakert
Aug 4, 2013 08:29 PM
YellowBomb
Jan 20, 2009 09:29 PM
White05LT
Nov 18, 2005 10:03 AM
