6th Gen ('00-'05): Dropping in New 3.8 liter motor
Old Jun 26, 2019 | 11:49 AM
Roestabotch's Avatar
Default Dropping in New 3.8 liter motor
I have a 2001 monte Carlo ss 3.8 liter motor is there a certain way to drop the engine in the car because I tried to go straight down but it doesn't seen to go in that way?
Old Jun 26, 2019 | 12:32 PM
Jeffs02rwdSS's Avatar
The engine will come out the top without any issues. You don't need to pull the hood , just remove shocks from hood and put a stick in place to hold hood up straight. Also put a jack under the transmission pan to support it when the motor is removed. Good luck
Old Jun 27, 2019 | 05:58 AM
Default Thanks you
Well I'm currently at a stand still right now because I can't seem to get the engine to line up with torch converter do that's were in at with it as of right now
Old Jun 27, 2019 | 09:44 PM
Agreed, the engine should come straight out no issues. Even the engine + trans will come out the top together if you tilt it.
As far as getting them mated, is your trans in or out of the car? I like it out better so it's easier to maneuver then I just bolt the converter on via the inspection cover hole after I've dropped it in.
Monte_Man04
Nov 2, 2015 06:01 AM
Darius Lovehall
Jan 20, 2015 04:59 PM
skntsqrl
Jul 21, 2010 06:55 PM
seanzyyy
Apr 21, 2009 04:14 PM
mavrickf1613
Jan 7, 2009 09:04 AM
