-   -   6th Gen ('00-'05): Dropping in New 3.8 liter motor (https://montecarloforum.com/forum/monte-carlo-repair-help-8/dropping-new-3-8-liter-motor-60921/)
Roestabotch 06-26-2019 11:49 AM
I have a 2001 monte Carlo ss 3.8 liter motor is there a certain way to drop the engine in the car because I tried to go straight down but it doesn't seen to go in that way?
Jeffs02rwdSS 06-26-2019 12:32 PM
The engine will come out the top without any issues. You don't need to pull the hood , just remove shocks from hood and put a stick in place to hold hood up straight. Also put a jack under the transmission pan to support it when the motor is removed. Good luck
Roestabotch 06-27-2019 05:58 AM
Thanks you
Well I'm currently at a stand still right now because I can't seem to get the engine to line up with torch converter do that's were in at with it as of right now
bumpin96monte 06-27-2019 09:44 PM
Agreed, the engine should come straight out no issues. Even the engine + trans will come out the top together if you tilt it.
As far as getting them mated, is your trans in or out of the car? I like it out better so it's easier to maneuver then I just bolt the converter on via the inspection cover hole after I've dropped it in.
