drls
Old Jun 18, 2005 | 10:56 AM
hersheybun88's Avatar
Default RE: drls
Any luck on disconnecting these damn DRLs yet?
Old Jun 18, 2005 | 11:03 AM
mickey's Avatar
Default RE: drls
yeah actuall you can do it but it will take ya a month of sundays to get it all done.
Seem GM got smart LOL
you have to take the solinoid out from under the hood and when looking at it like it was pluged in you have to splice the two wires on the right side. togeather but not threw the solinoid. to jump the action of it.
then you have a wire that comes off the switch in the dash it is a trigger wire. that will triger the low beams to act as your dlrs if the high beams are bad or out.
so you have to disconect it also
when you get all this done you should have no DLRS
so Thsi is the conclution i came to is do the same tign as TVM it is easier thent eh rest and you dont risk a fire from jumping the solinoid
also easy to fix later if you sell teh car. you will ahve to reenabel them or at least explin how to do it for the new owner.
Sorry guys this is the only way to stop current goign to the DLS ciruit
this is from a guy who workd on the eletrical systems on GM and Ford cars.
so i feel he is a pretty good sorce.
but if you want to try doing it get a wire digram and you will see what im talking about with the wires and where they are located on it.
IF my scanner was goign righ now i would scan the wire diogram he did the changes on so you could see it.
Old Jun 18, 2005 | 07:59 PM
montejass's Avatar
Default RE: drls
Wow, that seems like a ton of work... lol
Did it still dim the dash and radio lights as well?
TVW
Old Jun 18, 2005 | 11:05 PM
04MonteLS's Avatar
Default RE: drls
it doesn't really sound like alot of work, what was the hardest/most time consuming part of it? Getting the wire behind the dash?
Old Jun 19, 2005 | 06:12 AM
mickey's Avatar
Default RE: drls
tvm,this is why i just put a peice of tape over the sensor on mine . I had some smal round punch outs that fit it and worked so they wernt all over the dash ont he car but did the trick. I will be doing more perm fix when i do the guages.
but yeah way o much work for this just nt worth it.
Old Dec 5, 2005 | 12:03 PM
2000 SS's Avatar
Default RE: drls
Uh,you can shut off your drl's by following the directions in your owners manual, via the driver information system, I believe it displays on the radio. It controls several functions, inluding cabin illumination, door lock/unlock strategy, drl's, keyless entry settings, exit/entry lighting settings, etc.... I will post the instructions on turning off the drl's in a new post tonight.
Old Dec 5, 2005 | 01:03 PM
mickey's Avatar
Default RE: drls
belive me if you can i would really be a happy monte owner!!!
But i think that might be for the 02 models and lower i have a03 and a factory set of Manuals here and they dont even show you how to do it So if it can be done i would be real happy to know about it.
Old Dec 6, 2005 | 09:34 AM
Default RE: drls
Check out www.naioa.com to obtain a kit on disconnecting the drls and auto/on headlights. Trust me, it works!!! The user name at this site is : bbengineer who is selling it. i believe it is $75 and it plugs directly into the cars wiring harness. It should work on 2000 - 2005 Impalas and Monte Carlos
Old Dec 6, 2005 | 12:52 PM
mickey's Avatar
Default RE: drls
i like the auto on feture i just cant stand the dlr's and folks here flashing thier lights at me all the time is just annoying .
but the price is not to bad i guess. if i can have the auto on and the dlr;s off it would be worth it
rshovar
Apr 26, 2010 07:52 PM
Endo
May 2, 2007 12:20 AM
big green dog
Feb 16, 2006 05:09 AM
hersheybun88
Oct 11, 2005 11:35 AM
