Door Seals Leaking
Old Oct 31, 2018 | 01:52 AM
WolvenScout's Avatar
Default Door Seals Leaking
I had a huge problem with my monte leaking, like a pond size amount of water, which I mostly fixed thankfully, by using a silicone sealant on the sunroof. (removed carpeting, no obvious signs of rust.) But the door seals still leak. On the drivers side door in the top corner, the seal on the door is torn for about five inches. But odly enough, the water still getting in, seems to be coming from the passenger side, which isnt cracked or torn, just old. How do I replace the old seals on the door and the frame?
bossman48
Jun 15, 2018 10:57 PM
Radagast the White
May 20, 2014 09:41 AM
michelob
May 14, 2014 10:48 AM
postman2000
May 20, 2012 09:44 PM
Overdose666
Jul 12, 2010 01:55 PM
