6th Gen ('00-'05): Timing chain/oil pan gasket
Old Oct 30, 2018 | 09:01 PM
khel72's Avatar
Default Timing chain/oil pan gasket
I've got a 2000 ls and being broke I took on the leaking timing chain cover replacement and might as well fix the leaking oil pan while it's apart right? Got everything cleaned up and ready to reassemble and was thinking I should put the timing cover on first since you need to put sealant on the gasket where it joins to timing cover. Is this correct and/or thaought? Have manual and all data but they just have the process sepersepar not together. PSA it's not a very fun job for the novice but the shop labor was way out of my price range. Thanks
Old Oct 31, 2018 | 04:27 AM
Jeffs02rwdSS's Avatar
Putting silicone on the timing cover gasket is perfectly fine.Glad you're saving the money doing it yourself, probably can use money somewhere else. Good luck
kcarr65
Mar 29, 2017 10:33 AM
JoeD
Jul 21, 2014 11:57 PM
Andrew
Aug 7, 2013 08:51 PM
rmorman
Apr 16, 2012 04:35 PM
zk6216
Oct 25, 2008 05:10 PM
