2005 Monte SS Water in Passenger Door
Old May 20, 2012 | 09:07 PM
postman2000's Avatar
Default 2005 Monte SS Water in Passenger Door
Does anybody have any idea as to why I would get a puddle of rain in my passenger door after a storm? I guess some rain is normal but this is a lot of water..it sloshes around in there..I am going to check the door drains but even so I dont think this much water should get into a door..Thanks for any help..
Old May 20, 2012 | 09:23 PM
Mike 00LS's Avatar
Your door drain plugged up. That amount is normal given the circumstances. Several people whose drains clogged noticed sloshing sounds. You'll even notice rust forming near the bottom if you leave it too long. Clear the block from the door drain and you'll be fine.
Old May 20, 2012 | 09:44 PM
You may want to check the seals by the windows and make sure they are tight to the glass .
Jack
Jul 2, 2019 09:54 PM
MCSS06
May 29, 2015 08:04 AM
hillre48
Aug 15, 2010 08:50 PM
LonelyStoner
Jul 22, 2010 02:07 AM
Brooke
Oct 17, 2007 04:35 PM
