Dash Lights wont work at night
RE: Dash Lights wont work at night
Do a Test to determine if the fault is at the Bodywork Control Module or in the Wiring Harness and Fuses.
When the Instrument Panel Lights are OFF >> Test the Output of the GRAY Wire >> Coming-out of the BCM. The Gray Wire IS the Power Supply Wire to the Instrument Panel.
Inst Lites OFF / NO - 12V (Dead) @ Gray Wire = BCM Fault -or- Bad Ambient Light Sensor.
Inst Lites OFF/ +12V (Hot) @ Gray Wire = Problem with Harness, Fuse or Rheostat Switch Controlling Inst Lumination
Had the exact problem and fixed it. Theres a loose wire in behind your dimmer/light switch. Take off your dash (which is a lot easier than you think its like 5 screws and 3 clips, you might have to move your steering column around) and then theres 2 or 3 screws holding in the switch. Take em off and unplug the wire harness. Youll probably notice it right away. It might even have melted the plastic around it a little too. If you can resecure it somehow it great, however if you cant youll need a new one. Brand new from somewhere like autozone its about $130. However if you have access to a junkyard you can get it for much less. Ive noticed a lot of monte carlos have this problem for some reason.
