Crank no start
Old Feb 3, 2021 | 06:37 PM
Abonillas's Avatar
Default Crank no start
I have a 2004 monte carlo SS, i replaced the MAP sensor due to a code for it and cranking problem. it fixed it for a day then now it will only start with carb spray and will stay running on its own. i replaced fuel pump a month ago due to 16 psi when running. i checked the injector with a noid light and didnt have a pulse but have 55 psi fuel pressure and spark. used a volt meter to check if i have power front injector power wire and have 12 volts. any sugestions?
Old Feb 4, 2021 | 02:07 AM
xpage's Avatar
Try the ignition control module. I had mine go bad last year at 130k miles, had the same issue. Crank no start. you can find instructions on how to do so here
https://easyautodiagnostics.com/gm/3...-sensor-test-1
Other issue could be a bad coil, but it's like the ICM if cranking no start with no pulse
Old03SSDriver
Sep 28, 2019 06:42 PM
superss
Apr 14, 2014 08:24 PM
chio916
Mar 19, 2014 06:22 PM
needasmoke24
Apr 14, 2011 09:55 PM
gmonkey1969
Apr 25, 2010 07:04 PM
