ok a weird one
Old Apr 10, 2011 | 01:25 PM
needasmoke24's Avatar
Default ok a weird one
96 monte, no spark when cold? replaced crank position sensor, and the wire from crank to ign module, over 50 degrees sparks fine, under I have to pump the acc hard and it takes about 5 mins to start. I made the wire an extra 2 feet to route away from exhaust manifold, would that make a difference? Thanks all... I am not giving up on this car yet....
Old Apr 11, 2011 | 01:26 AM
nitehawkjcb's Avatar
Bad coils? IGN module bad?
Old Apr 12, 2011 | 12:55 AM
Default no I wish
Tested them, both good. man this must be electrical but????
Old Apr 12, 2011 | 06:45 AM
zipper's Avatar
Fuel Pressure Regulator?
Old Apr 13, 2011 | 09:44 AM
Default nope
Its a no spark, got 48 lbs at the fuel rail, just no spark.
Old Apr 13, 2011 | 10:04 AM
Did you check the cam sensor too?
Old Apr 13, 2011 | 02:34 PM
Yes cam sensor works fine, still baffled, started today its 60 degrees out. I am still on it.
Old Apr 13, 2011 | 03:11 PM
ok heres the deal I just couldn't start again, I tested the 3x sensor wire, I am getting just .1 volt should be between .3 and 1.0. I had the sensor and wire replaced, it must be one of those. sound logical.
Old Apr 14, 2011 | 10:49 AM
Check for shorts in the wire/connection, if the voltage isn't right, that would definately cause a problem.
Old Apr 14, 2011 | 07:22 PM
Default Found it
The underhood power center on the passenger side is cracked, and I have to wiggle it to start. Now to find the replacement. Any Ideas?
