6th Gen ('00-'05): help with my car dont know what else to do
Old Apr 14, 2014 | 06:55 PM
superss's Avatar
Default help with my car dont know what else to do
hey monte peoples i need some ideas on what to do next with my 02 monte the problem is it will start and run good for about 5 to 10 min then die and not rea start. i have the correct fuel psi and its a new pump,new fuel psi regulator,changed the injectors,and new fuel filter,new maf,new,tps,new,iac,new crank sensor,new cam sensor,removed the cat,new 02 sensor, plugs where new and the wires where a month old.changed the icm also the plugs are black as coal and dry after trying to start the car. the fans work and i ohmed the temp sensor. i also ohmed the wiring to the icm,cam and crank sensor and its good.i even unhooked the battery to reset the pcm and it wont start. it will try to start for a sec then just crank the vats is turned off in the pcm.the rear 02 sensor is turned off also and its a l67 engine swap. any ideas i posted about this before but had n0 luck. anyone else have a problem like this? or know what to do to fix it. when it cranks i have spark and fuel psi. when it dies the pump power is good.
Old Apr 14, 2014 | 08:19 PM
turbo monte's Avatar
my car is oing this as we speak. But mine only does it on a cold start and throws p0101 which is a maf code shutting down the car. I clear code and no issues till she cools down again.
Havnt figured out solution yet as it just started doing this sunday on way home from dyno.
Old Apr 14, 2014 | 08:24 PM
l67ss's Avatar
Check connects of vac hose and plug on map sensor
Monte98
Jun 22, 2011 12:46 PM
contra2443
Jan 17, 2011 01:54 PM
2003silvermontess
Jan 3, 2011 11:09 AM
Visceron
Oct 25, 2010 08:31 PM
mickey
Apr 7, 2008 10:30 PM
