cooling issues
Old Mar 24, 2010 | 06:30 AM
pdave22's Avatar
Originally Posted by Joe Bloggs
When I had this problem, I took it to the dealership expecting a simple fix. They ended up replacing the waterpump. This resolved the issue. They had to bleed it twice though. Original problem was due to no heat in idle position,, sound was present.
I just took mine to dealer too, same issue--replaced the water pump and flushed the coolant. They also said there was mud in the heater core and they cleaned that out. They said to do another coolant flush in 2-3 months
Old Mar 24, 2010 | 07:56 AM
MAMONTE's Avatar
You should flush the coolant at least every 25,000-30,000 miles, even Dex-cool. In fact ESPECIALLY Dex-Cool.
I was not having heater issues, but I had a leak, and the dealer replaced my water pump too.
Old Aug 4, 2010 | 03:09 PM
Kitty's Avatar
Default water noise in dashboard
I have a 2004 special edition Dale Sr #3 Monte Carlo has 35,000 miles on it, bought brand new in 2004. I have been experiencing water noise coming from the dashboard. I took it back to the dealership, they tell me nothing wrong. It just doesn't sound right, and even worse on acceleration. Anyone have any ideas. I do apologize if I have posted this in the wrong place, but this forum is new to me, and this is my first time here. Thank you for any input.
Kitty
Old Aug 4, 2010 | 03:12 PM
04 dale jr supercharged's Avatar
Check level
Old Aug 4, 2010 | 03:20 PM
I too had water sounds sloshing around the dash also a smell of antifreeze from the vents. Then heater core started leaking all over the carpet. I replaced my heater core with one from advanced auto(had to order the part cuz no one had on). No Problems since heat will melt your face off.
sled head red
Aug 16, 2011 11:51 AM
mikepp1977
Oct 20, 2010 06:42 PM
zk6216
Apr 13, 2008 02:49 PM
blazerman3
Mar 20, 2008 06:50 PM
87 Monte SS
Nov 15, 2007 04:01 PM
