Coolant Tempature Sensor OR ????
Old Feb 22, 2012 | 10:01 PM
06BlackJaySS's Avatar
Default Coolant Tempature Sensor OR ????
So a couple days ago my temp Gage dropped to the bottom. It will not read at all. So i changed the temp sensor- The one under the throttle Body and it didn't fix it. I have heard there is another one but cant seem to get any info on where it is at. Also since it stopped working my fans run from the time i start the car and then about 2 Min's after i shut the car off. Any ideas on this problem? And if there is another sensor where is it.?
Old Feb 22, 2012 | 10:33 PM
wiseheak's Avatar
Many times the code that gets thrown for the coolant temp sensor also means that your thermostat is bad. This happened to me a couple months ago, fans would run the entire time and my temp gauge didn't work. Once I replaced the thermostat everything was back to normal, in fact it just happened in my girlfriends' Saab 9-5 too. Coolant temp sensor code was thrown, I changed it, light was still on. Yesterday I just changed her thermostat and now it's back to normal.
Old Feb 22, 2012 | 10:35 PM
Alright, Great. Its worth a shot. I appreciate it.
Old Feb 22, 2012 | 10:37 PM
nitehawkjcb's Avatar
Yep, I was thinking a tstat also.
The other coolant sensor is on the radiator, to the left of the filler neck (at least that's how it is on mine)
Old Feb 23, 2012 | 08:19 AM
Isn't that the level sensor?
I would flush the coolant (if you haven't in a while) and change the thermostat. Air bubbles can actually cause the same problem sometimes.
The fans staying on is a precaution built into the PCM when it doesn't know how hot the engine was from the gauge not reading.
Old Feb 23, 2012 | 08:27 AM
Yeah Chibi it is, but that's the only other coolant related sensor I know of
Old Feb 23, 2012 | 11:50 AM
I don't know placement of coolant sensors on the 3400, but I know my '94 3100 (that the 3400 is based on) has a sensor in the rear head.
Old Feb 23, 2012 | 08:13 PM
It's Fixed. Disconnected the battery for a while and then I took off the upper Rad. hose and made sure all the air was out of the the system. Gage is now working and fans aren't coming on. Thanks everyone for the help.
f16fixr
Feb 3, 2009 09:20 PM
cali2000ss
Sep 13, 2008 11:27 PM
lanniec
Dec 15, 2007 10:52 PM
cimber
May 1, 2007 04:46 PM
enibum
Feb 25, 2007 12:25 PM
