coolant leak - stumped
Old Mar 21, 2013 | 09:23 AM
Victory's Avatar
Bolts stripped coming out and a big piece of plastic broke into the manifold. , was a pain in the *** taking it out , that was all
Old Mar 21, 2013 | 11:16 AM
aussiek2000's Avatar
The heads? Were you using a 15mm 6 point socket? J-shaped pick pulls the broken piece right out.
Old Mar 21, 2013 | 11:21 AM
The elbows were a pain doing them in my driveway. It sucks sometimes not having every tool available
Old Mar 21, 2013 | 04:30 PM
less than 30 mins with my tools at the shop. Guess that's where having the right tools make all the difference.
Old Mar 21, 2013 | 05:12 PM
Having the right tools makes all the difference. I think I'm with Aussie, I can do it in my driveway with the tools in my garage in about 30 minutes (not counting topping off and bleeding the system).
Old Mar 21, 2013 | 10:33 PM
Victory's Avatar
Having the right tools does help indeed, had to sit there and dig at her for a while. and by stripped I mean the threads.
Old Mar 21, 2013 | 11:01 PM
I've had luck with removing that the part of the elbow that is stuck in the LIM. I take a small screw driver and press one side of the old elbow piece towards the inside of the LIM. After that it spins and I can grab it with a set of needle nose.
Not sure if it's just luck or if it's a good way, but it's worked for me. Something to keep in mind for next time.
Old Mar 21, 2013 | 11:09 PM
nitehawkjcb's Avatar
Stripped screws/bolts suck. Screws more so.
With these cars: ratchet + extension + 10mm, 13mm, 15mm sockets = win.
STUMPMI
Oct 12, 2012 05:23 PM
shaneb66
Apr 19, 2012 10:38 PM
rupert1027
May 29, 2009 01:13 PM
mudbog42
Aug 16, 2008 12:34 AM
97z34
Jan 3, 2007 08:47 PM
