coolant leak - stumped
Old Mar 18, 2013 | 08:38 PM
Victory's Avatar
Default coolant leak - stumped
So i've had a coolant leak for the past 2 months and still haven't figured out where its coming from, I've changed the water pump and rad in an effort to fix the issue, both of which are fine... I did however notice a strange drip on the passenger side of the engine by the header valves (see picture)
Specs
3.8 L V6 LE SS
File Type: jpg
Old Mar 18, 2013 | 09:07 PM
Looks like your coolant elbows are leaking..
Old Mar 18, 2013 | 09:11 PM
These motors are notorious for leaking at the elbows...
That's what it also looks like to me.
Old Mar 18, 2013 | 09:13 PM
I agree and vote elbows. Being made of plastic, they eventually crack... Cheap and easy fix.
BTW - Do some research. For a while Dorman plastic replacements were having issues with pushing out (I had that happen first hand).
Old Mar 19, 2013 | 09:21 PM
Victory's Avatar
I would like to thank you all for your help, wouldn't have figured it was something so cheap, it however took nearly 2 1/2 hours to do , was not an easy job.
part of the brackets broke off inside of the intake manifold as well, that was quite the mess indeed.
Old Mar 19, 2013 | 09:24 PM
Glad you found your leak..
Old Mar 19, 2013 | 09:42 PM
Enzo354's Avatar
STILL SLOW
Mine only leaked when it heated up. I now have some aluminum ones in it.
Old Mar 20, 2013 | 01:00 PM
Victory's Avatar
aluminum would have been better but plastic should hold for a while
Old Mar 20, 2013 | 09:07 PM
Enzo354's Avatar
STILL SLOW
ZZP sells them for like $10 I think
Old Mar 21, 2013 | 05:15 AM
aussiek2000's Avatar
What part had you stumped?
