code reset question
Old Jun 7, 2014 | 02:43 PM
Scott 05's Avatar
Default code reset question
got the P0442 code yesterday, once cleared or reset how long till the system goes through its paces and would trigger it again if the problem didn't get fixed?
Old Jun 8, 2014 | 08:18 AM
There is no amount of time you can put til it pops up again... Unless you just cleared the code and didn't fix the problem that caused the code..it could show up the next time you drive it.
Heres a few things that will cause that code to pop up.
1. Defective or loose gas cap
2. EVAP canister or hose cracked- not connected
3. Purge or vent solenoid defective
4. Vaccum leak at engine
Have you checked/fixed any of these things?
montejass
FWD Tech Guides '95-'07
42
Sep 22, 2021 10:19 AM
greatness107
Sep 25, 2008 01:12 PM
PCWeber
Mar 11, 2007 10:58 PM
deadlifter
Feb 17, 2007 07:26 AM
malletboy
May 28, 2006 06:07 PM
