Check engine light issue?
Old Jul 28, 2011 | 04:08 PM
eastnjman's Avatar
Question Check engine light issue?
Sunday I tired to start my car and all the gauges went up and but the engine wouldnt start.After several attempts I left it alone.I thought it was the crank sensor and replaced it,still didnt work.So my mechanic used the OBDI 2 and got a P101 error if im not mistaken.Which ment i needs a Mass Air flow sensor.Replaced it and it worked like new.My issue is why didnt i get a check engine light on the dash?And is their any way 2 fix it? Every 1s oppion and thoughts are welcome Thanx....
Old Jul 28, 2011 | 05:17 PM
Perhaps the light blew out on the dash? Turn your car to the ON position, not starting it, the CEL should be lit.
Old Jul 28, 2011 | 09:19 PM
eastnjman's Avatar
No that light comes on when the car is on.Thats the first thing i checked.
Old Jul 29, 2011 | 08:06 AM
There are conditions for how many consecutive times a code must be thrown before it pops the Check Engine Light.
Basically, you car does NUMEROUS diagnostics while you are using it. If one of those fails, it logs a code. I think many of them have to fail three times consecutivly before it lights your Check Engine Light.
I've been doing a lot of work with a Snap-On ODBII scan tool. It can find out information such as:
Codes thrown this ignition cycle
Codes thrown since last cleared
Current Codes
Current codes are the ones currently causing the Check Engine light to pop up. I'm sure that Snap-On scan tool can get more then that, but that's a pretty cool amount of info to access!!
Old Jul 30, 2011 | 11:22 PM
eastnjman's Avatar
Whoa.I never knew that.Thanx for the info
Current Codes
hotrodharley
Nov 15, 2013 11:37 AM
bostonbcprs
Jul 7, 2009 10:47 AM
J_Bru_Ha_SS
Jul 30, 2007 09:08 PM
malletboy
May 28, 2006 06:07 PM
rich131
Dec 16, 2005 02:07 AM
