Cooling fan relay
Old Jun 11, 2012 | 12:13 PM
ohiobronco's Avatar
Default Cooling fan relay
One week after buying my car the "check engine" light came on while driving on the freeway. All the gauges looked good so I didn't panic and got it to the nearest Autozone. They hooked it to the computer and the code said I had a bad cooling fan relay. There were actually 3 relays marked "cooling fan" so I replaced all three. Started the car back up and the check engine light was off - so GTG right? Unfortunately the very next day the check engine light came on again w/ the same code! Anybody have a similar problem of know where to go from here?
Old Jun 11, 2012 | 06:00 PM
DRuben's Avatar
I might be having the same exact problem as you. One if the relays say cooling fans 2&3 and the other says cooling fan 1 I THINK. My cel has been on and off also. I also keep blowing the cooling fan fuse for #1. If i can remember correctly the code was ?P0480?
Old Jun 12, 2012 | 07:18 AM
ohiobronco's Avatar
That's the code! cel went off last night and back on again this morning. Anybody out there have any suggestions????
Old Jun 16, 2012 | 05:43 PM
DRuben's Avatar
Im not sure. My CEL hasnt been on since but still blows that fuse so im going to probably hard wire that fan to a switch...
Old Aug 28, 2012 | 12:35 AM
clement's Avatar
I'm sorry I can't seem to help you as I am also experiencing the same problem as yours. I already replaced my cooling fan relay but nothing happened it just keeps on coming back. Please can anyone help us out. Thanks.
NYGiantsfan
Aug 15, 2013 07:43 PM
MJClemm
Dec 12, 2012 02:21 AM
NYGiantsfan
Oct 16, 2012 07:51 PM
seth_06
Dec 2, 2006 05:42 PM
