Car started sputtering yesterday
Old Nov 15, 2018 | 12:42 AM
Denwin's Avatar
Default Car started sputtering yesterday
I know my o2 sensors are bad, any other opinions on what it could be?
Old Nov 15, 2018 | 06:23 AM
MAF sensor possibly.
Old Nov 16, 2018 | 02:14 AM
07ssman's Avatar
Did you run low on gas lately? Water and debris are very,very bad for engines. If it is that, it will burn off sooner rather than later.
Old Nov 16, 2018 | 03:45 AM
Denwin's Avatar
I might've,..I just started back driving it, it's been sitting up for past 3 yrs, been driving it for about 1 1/2 mos., recently got pretty low on gas
Old Nov 16, 2018 | 03:47 AM
Denwin's Avatar
how do I check, or can I clean it?
Old Nov 16, 2018 | 06:33 AM
Unplug it then try to start the car.. If the problem seems like its gone then its most likely the maf.
Some people have cleaned theirs and it worked. Ive tried cleaning 3 maf sensors in the past 10 years and it never worked. BUT I think thats because I ruined mine having a crappy air filter.
Old Nov 16, 2018 | 07:22 AM
Smile
You may want to change the Fuel filter, this will cause some sputtering if it has set for the 3 years.
Not sure what you have or engine but another thing to consider is the Catalytic converter may be plugged.
Old Nov 16, 2018 | 09:36 AM
07ssman's Avatar
The cat would throw a code. The one on my wife's SRX coded before there was even a hint of trouble, then coded again to let her know the mechanic put in the wrong cat. (All Cadillacs are 50 state emissions. $600 for that bit of trivia.)
Old Nov 17, 2018 | 09:58 PM
Denwin's Avatar
Default The car is a 2000 MC 3.4L
I put new wires (Duralast Gold), & AC Delco plugs, it still sputters but when it warms up , it gains its power somewhat, & the check engine is still on ( sometimes it blinks). I put a scanner on it, & I got trouble code P0300..
Old Feb 21, 2019 | 11:08 PM
cortesjr's Avatar
im thinking your cat is plugged
bowtiebandit23
Apr 9, 2015 10:13 AM
Coors
Dec 23, 2014 08:46 AM
phillyitaliano
Feb 28, 2012 12:22 PM
boyer61
Jun 13, 2011 10:35 PM
Epic
Nov 1, 2008 05:26 AM
