5th Gen ('95-'99): Please help!!!!
Old Feb 14, 2019 | 03:09 PM
dd850's Avatar
Default Please help!!!!
my M.C. has a "1st generation" window switch which needs replacing. the only ones avail. now are 2nd gen. which DO NOT fit. i know there is a way to re-wire the switch so that the 2nd gen. will fit, but i need a wiring diagram for the switch--driver's side master switch. I've searched since July 2018, and still haven't found the switch, or an EXACT wiring diagram for a 1995 Z34.
I'd apreciate any help with this very much!
Old Feb 14, 2019 | 11:00 PM
Question
Here is a link to ebay buy the Factory service manual for this info. Also you may need to find a U-pull it salvage yard and get the switch from a Lumina or a Monte Carlo.
It could be a simple as changing the connector plug. You could get that wire section with the plug from the salvage car and then wire it up to your car.?
https://www.ebay.com/sch/i.html?_fro...+1995&_sacat=0
Old Feb 22, 2019 | 12:50 AM
mr markuSS's Avatar
Jeffs02rwdSS
Feb 26, 2019 04:58 AM
dd850
Oct 20, 2018 11:18 PM
Onion39
Jul 26, 2018 08:30 AM
JaLo
Jul 11, 2014 02:56 PM
Chainsaw
Oct 25, 2010 01:22 PM
