Im lost
Ok, well my fiances mom ran her 03 Monte Carlo out of gas. She had someone put 10 bucks worth of gas in it and it started.
For the longest time it would only start with the gas pressed down and that was it. Then all of the sudden it started, ran fine idled normal and everything.
I got it home, after it died once one the way home, and changed the plugs, wires and fuel filter. What a PITA. Started the car up, ran like a champ. Drove it to the gas station, put 10 more bucks in it and drove it about 20 miles, shutting it off every now and then. Ran perfect.
I was just gonna go take it back to her house, until i started it back up, and it started doing the same thing again. Then all of the sudden it ran fine, and idled fine. Turned it off, and it started doing the crappy idling and wouldn't hardly start.
What can this be?? No codes being thrown at all. I'm lost..
Please help me out
It's a 3.8L NA
Please help me out
It's a 3.8L NA
Just a guess, but I know around here $10 isn't going to put much gas in the tank. If the tank was run low on a regular basis (especially during the winter) there could be a fair amount of condensation (water) in the tank mixing with the gas and diluting it.
Thank you for the reply, she does run it very low, all the time.
I'm gonna put some additive in the tank to get rid of the water and i'll fill it up.
But it seems odd cause for the longest time i could drive it and it was acting perfectly..
Not to mention the fuel pump can burn up if the gas level gets too low.. The fuel lubricates and also cools the pump (if it is submerged). As a result, I've never felt comfortable letting my car get to the point where the "Low Fuel" message pops up. If you have an older car with a mechanical pump though, it's a bit different because the pump is attached to the engine and lubed by engine oil. I usually put gas in her when it usually gets right below the 1/4 mark.
First, I agree, if you're running it LOW all the time, perhaps a condensation issue.
If it acts this way on a FULL tank, the next items I am wondering about are coil packs and fuel pump. I had experience with a coil pack before randomly acting up (I found it ENTIRELY by accident, in my case, apply pressure to it a certain way caused the car to run like crap, change the pressure and it was fine. Next time I suspect a failed ignition coil, I will be re-reading this article:
View topic - Comprehensive guide for troubleshooting Ignition coils : PontiacBonnevilleClub.com
Well I just took it for a drive. Nice long 45 min drive. Ran perfectly. Then all of the sudden the track off light comes on and it says service traction system. And it dies. Still no codes. I poured some Herr on the tank before I left. Every now and then it'll start, idles normal the suddenly sputters and dies
