6th Gen ('00-'05): New MAF sensor, P0172 a week later.
Old Apr 8, 2015 | 03:44 PM
bowtiebandit23's Avatar
Default New MAF sensor, P0172 a week later.
So I replaced my faulty MAF sensor about a week ago (week ago, week ago) and today I got hit with a P0172 which is running rich/lean. Could that have anything to do with the new sensor picking up something the old sensor didn't? Or just coincidence that the bank 1 and or 2 went?
Old Apr 8, 2015 | 08:31 PM
JC Colon's Avatar
Did you replace you MAS with a Delco? Aftermarket MAS don't meet the ridged specs GM put in for these cars.
The new MAS could be causing that code but it could also be that now that you have gotten the new mass the before cat O2 sensor is bad and not reading right.
Old Apr 9, 2015 | 08:30 AM
Yes it is an AC delco. Read a lot of threads saying that you def have to have AC delco parts for our cars to work properly. It could just be a bad sensor. Good thing I'm getting a zzp down pipe soon
Old Apr 9, 2015 | 09:36 AM
03SSLE's Avatar
A bad MAF could cause the code, but so could a bad injector(s) or Bank 1 O2 sensor. Since the MAF was the last thing worked on prior to the code I would go back to it and double check your work. Maybe a leak around the mounting flange?
Old Apr 9, 2015 | 09:46 AM
Where exactly is this Bank 1 sensor 1? And is there a bank one sensor 2? Print out just said bank 1, not specific to which sensor.
Old Apr 9, 2015 | 09:57 AM
03SSLE's Avatar
It's located in the rear exhaust manifold.
Old Apr 9, 2015 | 10:02 AM
Which sensor is the best to use on our cars? Bosch?
Old Apr 9, 2015 | 10:13 AM
03SSLE's Avatar
I would use an AC Delco or a Delphi - BUT - I would double check installation of the MAF before spending any more money. You may end up buying something you don't need.
2000montecarlo
Jan 21, 2012 07:37 PM
jglancy87
Mar 22, 2011 08:45 AM
steelmalu43
Aug 8, 2008 04:23 PM
CHOWEE21
Apr 6, 2008 07:26 AM
spills
Dec 30, 2006 09:55 PM
