cabin air filter
Old May 11, 2013 | 02:20 PM
ssdriver's Avatar
Default cabin air filter
I have an 05 Monte and it does not have a cabin air filter. Were they standard on only certain models that year or strictly optional equip. What's up
Old May 11, 2013 | 04:47 PM
Your '05 SHOULD have a cabin air filter. To get to it:
- Turn on the wipers and turn off the car when they are pointing straight up (should keep them out of your way).
- Looking at the cowl cover under the windsheild, you should have a "split" cowl cover (it's 2 pieces instead of one long one).
- On the passenger side, you have to remove a bunch of plastic push rivets/pins/holders (they are re-usable). Remove them around the passenger half of the cowl cover.
- Lift the cover off and there it should be (unless someone removed it).
This thread better illustrates everything:
https://montecarloforum.com/forum/si...lem-fix-26663/
Old May 12, 2013 | 06:00 AM
ssdriver's Avatar
My cowl is one piece, no split.
Old May 12, 2013 | 06:04 AM
It might look like one piece but it definitely shouldn't be
Old May 12, 2013 | 07:57 AM
Odd that GM would have changed that on the '05 Monte (the shop book also notates a split cowl). Regardless of split cowl or one piece cowl, the cabin air filter is still there.
If you look at the permanent cabin air filter fix thread I posted, it shows step-by-step pics and descriptions that gain you access to the air filter. Attached are 2 images from the '05 shop book.
File Type: jpg
File Type: jpg
Old May 12, 2013 | 12:01 PM
ssdriver's Avatar
I'll take a closer look. My owners manual references the cabin filter if so equipped.
Old May 17, 2013 | 06:57 PM
ssdriver's Avatar
For those interested my car does have cabin filter and the cowl cover is split at the midway point. Replaced filter and installed the "deflector" as GM calls it install was a piece of cake.
Thanks to all.
Laserblue06ss
Oct 25, 2023 08:51 AM
fastback4
Jun 14, 2008 06:03 PM
God_Bot
Mar 14, 2008 07:24 PM
RickCoMatic
Dec 16, 2007 07:15 PM
03SSdriver
Oct 5, 2005 08:13 PM
