Cabin Air Filter?
Old Mar 9, 2008 | 04:03 PM
God_Bot's Avatar
Default Cabin Air Filter?
I was browsing and came across this cabin air filter.
Now I remember a post a while back about this filer but was unable to locate it.
Here's my question, do we have one of these in our '06-'07 Montes? If so where is it and has anyone switched theirs out yet?
I've had this car since Aug. '06 and have driven on more than my share of dirt roads so I figure that it probably needs replaced if I do in fact have one, or atleast blown out.
Old Mar 9, 2008 | 05:36 PM
bowtietech's Avatar
Default RE: Cabin Air Filter?
Yes,the '06-'07 Monte Carlo does have a cabin air filter.It is located on the passenger side,below the plastic cowl cover beneath the passenger wiper arm.Here is the replacement procedure directly from GM Service Information...........
2006 Chevrolet Monte Carlo | Impala, Monte Carlo (VIN W) Service Manual | Document ID: 953956
[hr]
[/align]Passenger Compartment Air Filter Replacement [/align]
Removal Procedure
[ol]Position the windshield wipers in the UP position, by keying the ignition OFF when the wiper reach the desired position.
Open the hood.
Position aside the rear hood seal halfway to the center. Refer to Hood Rear Seal Replacement .
Remove the washer hose from the right air inlet grill panel and position aside.
Remove the 2 push pin retainers from the right air inlet grill panel.
Important:Do not remove the third push pin retainer from the right air inlet grill panel.
Position the left side of the right air inlet grill panel on to the windshield.
Remove the water deflector cover.
Remove the passenger compartment air filter. [/ol]
Installation Procedure
[ol]
Install the passenger compartment air filter.
Install the water deflector cover. Ensure the three tabs of the water deflector engage the rear cowl edge.
[/ol][/align]
Old Mar 9, 2008 | 08:01 PM
God_Bot's Avatar
That is wonderful information, I think you deserve like five posts for that. Thanks
Old Mar 9, 2008 | 08:12 PM
blackbeauty's Avatar
Does a 03 monte carlo have this as well?
Old Mar 9, 2008 | 09:03 PM
bonang's Avatar
I think every new chev that as the air exchanger has one.
You deserve a cookie casue I am getting a werid smell when put the air exhanger.....might open the cowl and check this out tomorrow.
Old Mar 9, 2008 | 09:35 PM
RickCoMatic's Avatar
When I got around to finding mine ... after looking all-over behind the glove compartment ... The Forum came to my rescue with the info as to where it is too ...
When I got the thing out ... It was Soooo badly clogged I couldn't imagine air passing through it.
You can cut slivers of an air freshener an put the slivers in the vanes of the new filter for a nice smelling cabin when you switch-on the A//C
Old Mar 10, 2008 | 02:41 AM
jay26's Avatar
is the procedure the same in a 01 monte?
Old Mar 10, 2008 | 03:21 AM
03SSdriver's Avatar
Yes, the 03 has oneas does the 01. Procedures are the same.
Old Mar 10, 2008 | 07:18 AM
dustybird3's Avatar
Photobucket
Monte Of The Month - April 2008
I've looked all over the place, no wonder I couldn't find it, it's buried, LOL.I'll have to golook again.
Thanks
Old Mar 14, 2008 | 07:24 PM
rj's Avatar
rj
What's the recommended interval for changing these? 12 months, 12k miles?
I have no idea how my '06 was driven before I got it? Maybe it was taken down the dustiest roads in the midwest on a daily basis? It's possible if I were to check this filter I'd swear it came from ancient Egypt?
Laserblue06ss
Oct 25, 2023 08:51 AM
Gordons24
Dec 30, 2008 01:28 PM
fastback4
Jun 14, 2008 06:03 PM
RickCoMatic
Dec 16, 2007 07:15 PM
03SSdriver
Oct 5, 2005 08:13 PM
