A/C won't turn on
Old Apr 19, 2010 | 10:32 PM
drewskie043's Avatar
Default A/C won't turn on
hi all. so i went to turn on the A/C today and the light on the button flashed 5 times and shut off again. obviously, there is something wrong in the system and i'm hoping it's somewhat simple. i checked all the fuses and relays so far, but i haven't go that deep into it yet.
i guess my question for you GM techs out there is: what is the AC system pressure supposed to be at? i have a hunch it could be a bad pressure sensor and i have a device at work that i can screw the sensor into and simulate a given pressure to see if the sensor is good or bad. hopefully it isn't as bad as replacing a whole condensor and/or compressor pump. the local stealership wants $131 just to diagnose the problem! flippin rediculous!!! i'll do more troubleshooting when i get a chance along with looking for a more reasonably priced auto repair shop if necessary.
any info would help, thanks everyone!
Old Apr 21, 2010 | 08:22 AM
K-Mac Attack's Avatar
I hope your condenser is ok...I just had to have mine replaced. I paid $325 to have it done. Mine was losing refrigerant out the top of the condenser. Sounds like a sensor though since you are getting a flashing light. Mine just didn't blow cold and the compressor wouldn't kick on since the system was empty.
Old Apr 21, 2010 | 08:34 PM
Justin Knight's Avatar
If the button is flashing and its not turning on ask a Gm dealer to check the HVAC codes for your car you need to have a Tech 2 scanner for this. It may just be a sensor but it could also be the control head or another electrical malfunction. Also to my knowledge a gen 7 mc will have a ambient temperature controlled a/c system, meaning if its not hot enough outside it won't turn on whether you turn it on or not.
Old Apr 21, 2010 | 10:04 PM
monte07's Avatar
mine turnes on when it is 60 degrees out side. i had the same problem it ended up being the hvac controlls that trun it to worm to cold there is a conector in side the switch that went bad dont know why but it is quite new you should not have problems with the a/c compared to older vehicles. as in parts being very worn out. have it checked as well at a place that is gm certified to acuretly know where the problem is.
Old Apr 22, 2010 | 07:23 AM
as stated in my first post, i did call the dealer about this issue and yes, he said there is probably a code to be read. however, he wants $131 dollars just to pull the code. "F" that! i'll find someone else with a tech 2 and get it done for waaay less i'm sure.
the ambient air temp was 79 degrees when i discovered the problem so i'm sure it wasn't cuz it was too cold.
i'm gonna do some of my own diagnostics here this weekend when i get a chance, check system pressures, etc. it might be as simple as re-charging the system with refrigerant and stop leak additive if there is a tiny leak somewhere. i'll be back with updates.
Old Apr 30, 2010 | 09:07 PM
stop leak additive is death to the a/c system and should never be used just a warning. if your engine was leaking oil would you pour glue into it to try and stop the leak? thats what a/c sealer is.
Old Apr 30, 2010 | 09:48 PM
mak330's Avatar
i didnt even read your post but try these things.
make sure you dont have the **** turned to the red/hot setting.
it doesnt turn on and blink like that when you dont have the fan *** on.
when you try to turn it on you should hear a click.
have someone turn it on and i think its the bottom accessory, it should make a noise and start to spin.
you really shouldnt be out of refrigerent, but do a refill.
they have those hvac dash pieces for like 35 bucks on morads or ebay.
the only time mine personally does that blinking is when i dont have the fan on and im trying to hit the a/c button.
GL
plus small shops have scanners. the guy i go to has a a bunch of mac scanners that do everything. go to small garages and ask them. usually its 35 bucks, and they/ll waive the fee if you get the work done there
jeff2425
Dec 9, 2009 07:05 AM
rgant_19
Jun 3, 2009 05:16 PM
dougied
Mar 5, 2009 03:21 PM
jeff2425
Jul 26, 2008 07:29 PM
ww
Mar 17, 2007 01:50 PM
