p0141
Old Apr 29, 2010 | 06:43 PM
dirty mech's Avatar
Default p0141
my engine threw the code p0141 which read out to be heater circut malfunction and it turns out that is the o2 sensor from bank 1 sensor 2 which o2 sensor is it that needs to be replaced
Old Apr 29, 2010 | 08:52 PM
Justin Knight's Avatar
B1 S2 is the post cat sensor, but if its a heater circuit code the ground for the sensor is likely the cause. check for water intrusion to the harness and corrosion, even a melted harness. the other good thing to do is determine the ground wire for the heater circuit and add a piece of wire and ground it on the chassis for a better ground.
Old May 2, 2010 | 02:49 PM
dirty mech's Avatar
thanks for the information i am going to have to check it out and see thanks
can2tx
Nov 18, 2013 02:20 PM
Leprechaun93
14
Mar 30, 2013 08:53 PM
StretchMC
Jun 19, 2009 08:45 AM
