A/C Knocking
Old Jun 25, 2012 | 01:02 PM
rainygirl's Avatar
Originally Posted by 03SSLE
If the A/C was working fine prior to the repair I'd double check my work making sure the actuator mode\temp valves and air inlet are installed correctly.
haven't fixed or changed anything yet, new symptom....
Old Jun 25, 2012 | 02:07 PM
03SSLE's Avatar
Oh, okay. Well if you were getting the clicking noise that means the actuator was malfunctioning. Are you still getting the clicking sound? The actuator may now be stuck in the heat position so none of the cold air is making it to the vents. Kinda like having the heater on even though the controls are set for A/C.
Old Jun 25, 2012 | 02:15 PM
rainygirl's Avatar
THANK YOU! THANK YOU! THANK YOU! thats exactly what I needed to know, I wish you many years of happy motoring!
Old Jun 25, 2012 | 02:21 PM
03SSLE's Avatar
No problem...let us know know how many busted knuckles and broken nails it takes to get it fixed.
Old Jun 25, 2012 | 02:44 PM
joeykl66's Avatar
i have the same problem. gonna take it to the dealer. luckily mine is still under warranty.
Old Jul 1, 2012 | 01:22 PM
DOLO CARLO ANGEL COUPE's Avatar
I have an 06 ss monte... Mine started knocking about 2 years ago and is still doing it till this day....i dont know wtf i can do. Dont really have money for repairs. Looking forward to looking at this how to vid on youtube
Old Jul 3, 2012 | 11:07 PM
rainygirl's Avatar
All right..... so turns out the a/c blend door actuator is an easy fix.... had two on the passenger side that needed replacement. Took them... opened them... and robbing peter to pay paul, was able to make one good one by swapping gears and only had to buy one for $38.00. didn't have to remove the dash just pulled out the glove box. 4 broken nails, one busted knuckle, and one sliced thumb later the a/c doesn't knock anymore but isn't blowing cold either....so after three hours of trouble shooting i think i need to change the compressor clutch coil....FML
Old Jul 20, 2012 | 02:29 AM
TPC9183's Avatar
mine started ticking a couple days ago..... i knew i could count on this site to tell me what my problem is lol well i guess i get to get some busted knuckles now prolly no broken nails though i keep em short lol i can for sure see a sliced thumb in my future too ...... just one question how do you know which of the 3 on the passenger side is the malfunctioning one?
Old Jul 20, 2012 | 03:32 AM
MillerMonteSS's Avatar
2010 Monte Of The Year
I would have an assistant change the settings on the climate control while you are looking at the actuators. You should be able to see the one(s) that is(are) causing the noise.
BLACK ATTACK
Dec 5, 2007 11:57 AM
krowziviche
Jun 14, 2007 11:55 AM
michael2938
Jan 16, 2007 02:34 AM
ralphtrent
Oct 27, 2006 07:13 PM
clayg80
May 4, 2005 11:10 AM
