brakes dragging
Old Mar 17, 2010 | 06:18 PM
supercharged SS's Avatar
Angry brakes dragging
So did a brake pad change on my 98 monte and when i went to put the caliper back it now drags on the passenger side. I tried backing out the bolts so it wouldnt drag but lost one and almost lost the other one (it was dangling) so i buy new bolts put them on and tighten the bolts down too much im assuming so it still drags what am i doing wrong the other side works fine no problem can some one guide me please
Old Mar 17, 2010 | 07:04 PM
Tried backing out what bolts? You left braking system bolts loose to keep the caliper from dragging?
Did you grease the slide bolts? If you did, then the caliper may be going bad- getting hung up.
You definitely aren't supposed to leave bolts loose though- everything should be torqued like normal.
Old Mar 17, 2010 | 07:09 PM
yeah thats what i thought, i did grease them but i guess i can try and regrease them again
Old Mar 17, 2010 | 07:22 PM
monte07's Avatar
i do have a question was it hard for that poticular caliper to push in the pistons? if it was a little hard it also a sign of some thing going wrong as in needing to be replaced.
Old Mar 17, 2010 | 07:42 PM
well I used the tool from autozone and it was simple to go in not really difficult at all so im seriously
zzapultimate
Aug 8, 2011 09:25 PM
ralphtrent
Dec 14, 2005 12:09 AM
Scooze
Oct 20, 2005 03:58 AM
Matthew
Jun 19, 2005 03:25 AM
Juve
Dec 1, 2004 12:46 PM
