Master Brake cylinder
Old Sep 27, 2012 | 08:41 AM
maxwell4's Avatar
Default Master Brake cylinder
God morning,
Still have a 1995 Monte Carlo, that I bought in April 1994. It has been sitting inside car canopy for last two years. I finallly thought it was time to move it. When I went to apply brakes when first backing up, pedal went to floor but stopped. Checked brake reservoir, it was empty so I filled it. Applied brakes again same result. Left resevoir lid off, applied brakes, no bubbles or signs of fluid movement. So I presume Master Brake cylinder is gone. New cylinders aren't that much, but with ABS it looks like a chore.. Any info or instructions on how to swap out would be helpful.
Ted
Old Sep 27, 2012 | 08:54 AM
So you had no fluid, then topped it off?
The cylinder might not be bad, you might have a leak in one of the lines or just need to bleed the lines.
Old Sep 27, 2012 | 10:49 AM
03SSLE's Avatar
^^^ I agree with Mike ^^^
If the car lost the fluid in the master cylinder while sitting for 2 years I would suspect a leak in either a line or a caliper. I'd give the entire brake system an inspection prior to committing yourself to a master cylinder R&R. That much fluid leaking out should be fairly easy to spot since the car has been sitting.
Old Sep 27, 2012 | 12:52 PM
maxwell4's Avatar
When I put fluid in master cylinder and left cap and pump pedal, there is no movement in fluid in cylinder or even overflowing onto reservoir by pumping pedal..Thats why I thought it might be bad,
MonteMonkey
Oct 15, 2014 03:58 PM
05montecarloyo
Aug 8, 2012 07:02 PM
Doozer
Jan 19, 2012 02:04 AM
qzack1
Aug 28, 2011 12:50 PM
johnm
Jan 10, 2011 02:16 PM
