Brake Caliper bolts HELP!!
Old Dec 4, 2013 | 08:41 PM
zell's Avatar
Default Brake Caliper bolts HELP!!
trying to find Rear caliper bolts for my 06 Monte! autozone and kragen does not have them. I am looking all over the internet but the ones popping up online are either front caliper bolts or WRONG entirely! can anybody give me any hints as to how to find these? and please do not say the manufacturer because id like to find them online TODAY so i can hopefully enjoy my weekend!
This is the EXACT bolt I need...
File Type: jpg
Old Dec 4, 2013 | 09:21 PM
Most parts stores sell the caliper pins, not sure about the bolts. I assume this is the bolt that holds the bracket to the spindle?
That type of a bolt (flange bolt) in my experience is typically a dealer item.
These are the options I see:
- Dealer
- Junk Yard (as I'm sure other models of Monte and Impala use the same bolt)
- Go to the hardware store, instead of a flange bolt, get a bolt long enough with a washer (not sure if this is a hardened bolt or not). Should not be a big deal if it's threaded all the way up.
Piece of advice, get Loc-Tite. Those bolts can come loose, even tightened pretty hard (I've had it happen, only to find the shop book tells you to use a thread locker). I've used Red Loc-Tite with no issues (and I can remove the hardware by hand without using heat).
Best of luck!!
Old Dec 4, 2013 | 09:33 PM
JC Colon's Avatar
Have you tried NAPA? They are better at having parts that are considered "Dealer Only Parts" !
Old Dec 4, 2013 | 09:37 PM
zell's Avatar
Thanks maniac, I think this stupid bolt is going to be harder to find than i thought.. I BELIEVE ive found it here:
SUSPENSION/REAR. Fits: 2006 Chevrolet Monte Carlo | Tonkin Online Parts
(Item 21)
but im not going to pay 25 dollars for a part that will take up to 4 days to process... guess ill try the hardware store tomorrow. I was considering putting anti-seize in before i re installed the calipers, but i use loc-tite on my weapons and once you add that stuff to a bolt and screw it in, there's no way your getting it out.. is that really something you would consider??
Old Dec 4, 2013 | 10:16 PM
l67ss's Avatar
If it doesnt work out i can get you the bolts
Old Dec 4, 2013 | 10:45 PM
YES! And the GM Shop Book instructs you to use it. I had to replace a front caliper bracket bolt on the Monte (had to get it at the dealer) and the OEM bolt from the dealer comes of a dry version of Loc-Tite on it already.
Based on about 3 instances of brake calipers that use a bracket having a bolt back out, I won't do a brake job on this type of setup without loc-tite. Search the Internet, all manufacturers, Ford, Dodge, etc, at least one person has a post claiming a brake caliper bracket bolt fell out. Given it happened to me personally and I know how tight they were installed, yeah, it's important.
Old Dec 5, 2013 | 09:40 AM
1996 Red/3.1 Monte's Avatar
Default bolt
You could visit a Chevy dealer and have them pull the bolt up for your car and if they don't carry a replacement on their parts shelf, another GM dealership in the local area may have one on their parts shelf if this a a common replaced item.
Get the part number for your bolt and check with other GM dealers.
The cars service manual may specify replacing these bolts rather than reusing the original when brake work is done and the bolts could be on their parts shelf.
My Chev dealer has had parts the next day when I ordered.
HIxArsenaL
Jan 25, 2014 08:10 PM
Crazy4408pac
Feb 19, 2011 12:18 PM
mavrickf1613
Apr 28, 2008 07:36 AM
RocknSS04
Nov 16, 2007 08:59 AM
zipsayain
Mar 31, 2007 09:35 PM
