caliper bolts
Old Feb 18, 2011 | 05:16 PM
Crazy4408pac's Avatar
Default caliper bolts
Anyone tell me what type of mounting bolts, are on the front calipers.
98 Monte LS. Are they torx or regular metric type heads?
Size would be helpful, also. Going to be replacing the roters and pads, laying on my back in the snow. So would like the correct tools, before I get wet.
Thanks
Old Feb 18, 2011 | 05:59 PM
kweef's Avatar
idk which it is but fyi if it isnt a torx it will be metric not sae
Old Feb 19, 2011 | 12:03 PM
From what I remember the calipers are regular metric bolts (not sure on the size)- but the brackets (to get the rotor off) is a T60 Torx.
Old Feb 19, 2011 | 12:18 PM
mrl390's Avatar
Rear calipers use a 15mm bolt and I believe its the same for the front ones. And like bumpin said, the brackets themselves use a torx.
zell
Dec 5, 2013 09:40 AM
LW57912
Mar 27, 2010 08:49 PM
nitehawkjcb
Jan 6, 2010 01:46 AM
turbo895
Jul 15, 2008 01:33 AM
montecarlomike81
Feb 22, 2008 08:28 PM
