Best way to get a downpipe off?
Old May 29, 2013 | 06:30 PM
Spiked's Avatar
Default Best way to get a downpipe off?
So what would be the best way to take the downpipe off an 04 SS? Going to be replacing the cat and just want to know
Old May 29, 2013 | 06:37 PM
I would use a socket or a wrench .
I would use bp blaster on the bolts
Old May 29, 2013 | 10:20 PM
I would spray it down with PB blaster penetrating oil several times before attempting to break it loose. I would use a 6 point socket or wrench because they grab better. Heating it up with a torch will work too if that is an option.
Old May 29, 2013 | 11:14 PM
nitehawkjcb's Avatar
If you have enough room, use a socket. Otherwise you'll need a wrench. Mine are 15mm bolts.
Old May 30, 2013 | 06:24 AM
I got to all the bolts from under the car. I was lucky the ones on the rear manifold broke free (I had to use a monster long extension on my ratchet to get them, but it worked).
Old Jun 25, 2013 | 10:26 AM
Spiked's Avatar
What would be the best way to get it off the front part of it? I already got the back off near the resonator, but I can't figure out how to get the front off
Old Jun 25, 2013 | 11:49 AM
I repeat, I did mine all from under the car. When you say front part, I assume you are talking where the downpipe and rear exhaust manifold meet...
I had front of my car as high as I could, the rear wheels blocked. A ratchet and some long extensions to reach the nuts/bolts holding them together. A little hit with some PB Blaster prior to and during the job and all came apart perfectly. I did zero work for the downpipe from up top.
I'm sure others have done this job differently.
Old Jun 25, 2013 | 06:37 PM
mairj40's Avatar
I sprayed mine with PB Blaster and let them soak. Then I put the car up on ramps and slid under it. Using a long extension, I was able to break the bolts free from the manifold/downpipe very easily. It was super easy to do.
Old Jun 25, 2013 | 08:15 PM
Spiked's Avatar
Thanks for the help guys! Greatly appreciated!
iMuf
Jan 31, 2013 02:30 PM
Chev E. Chelios
Feb 23, 2011 03:54 PM
1BADSS
Dec 1, 2009 11:21 AM
monte carlo 3831
Jul 9, 2009 09:03 PM
alabamamonte
Nov 14, 2008 11:42 AM
